Moving License from one Device to another Device in one Organization
I have a question about moving a license. I have 1 Meraki MX64 with enterprise license which used and plan to buy one more for backup unit and it will use if the first Meraki broken. How can I move the license from the first Meraki to the Backup unit or Should I buy an enterprise license for the backup unit? I couldn't found docs about it.
@Noffal This article will help you. If you are setting them up as a HA pair then you only need the one license, if you want to physically swap them yourself I would purchase a second license.
If you are not using an HA spare; you only need a licence for an MX in a network. So if you want to keep a cold spare you can without an extra licence.
Yes, that's right, I will use the second MX for Cold Spare. So, If the first MX broken, I just add the Cold Spare MX to network from Inventory (unused) which I claimed before, right?
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_a0887628ad189","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_a0887628ad189_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_a0887628ad189_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_a0887628ad189_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_a08875b710edb","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
