Hello all,
Does anyone know if Meraki will make the web interface to automatically fit any size of screen?
In the wireless access point list view, it is quite inconvenient when searching and navigating through all the columns you can add. Most of the screen is empty, and the table with the AP information only fills a predetermined size that cannot be adjusted.
Thank you so much in advance!
Have you tried in another web browser?
Hello @alemabrahao,
I have tried with Google Chrome, Microsoft Edge and Firefox. Unfortunately, the web interface view remains the same. The table with the AP list does not feed the size of the screen.
This is an open bug/known issue since a few weeks ago
Hello Ryan,
I am glad to hear that this is a known bug/issue. Unfortunately, for us, this behavior has been present for a while now.
Do you happen to have an ETR for his?
I do not. If you open a Support case they can tie it to the master issue being tracked so when there are updates you'll be notified.
Hello Ryan,
I just submitted a case as suggested.
I will keep you posted and let you know the outcome of the discussion with the Meraki support.
I hope that it can be fixed soon..
Thank you so much for your help!
