I just wanted to see if anyone is experiencing this today. The iPad is being setup and checking into Meraki in the dashboard but the app is reporting the iPad is not enrolled.
This is a HUUUUUUUUUUUUUGE problem as new iPad setups are not able to download Apps from Meraki.
Not enrolled
Dashboard view
I am getting ready to call support but wanting to see if others are experiencing this pain as well.
Solved! Go to Solution.
We just started pushing a fix out. If you don't see it fixed within the next hour please call Support.
We'll take a look and update this thread when we have more info.
I'm currently working with Tahir in support, my case number is 05615616.
Please feel free to drop devices into my Meraki instance if you need to test on your end.
I gotta say the new Beta SM app is pretty slick. I hope we see it released soon.
We are seeing the exact same issues with 7th Gen iPads that we just received. Any resolution yet?
