Hi IanAce,
Welcome to Meraki Community!
We would like to sincerely apologize for the caused inconvenience.
In addition to spaladug comment, there is a workaround at the moment, using the old version of the Client's page under Network-wide>Client section>On the top right corner on the page.
If you have any questions, please don't hesitate to contact us.
