Simple question, is there a way to manually edit the Network Topology?
Solved! Go to solution.
no, its just a dynamic view of the lldp/cdp topology. but you can make and edit drawings with tools like visio.
https://www.cisco.com/c/en/us/products/visio-stencil-listing.html
Thank you.
One other comment, note that you can export (download button) the topology to an SVG file and import into Visio.
