- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Is there a way to extract specific configuration components in an organization.
Fairly new to Meraki and trying to establish if there is a facility to generate some sort of report for all network in an organization as relates to a particular element.
For example if I have an organisation, with say 800+ networks on it, and I'd forgotten to set the local time zone (national customer with choice of 4 different timezones, can I get a report showing all the network and their current setting.
This allows one not to have to go and look at each of those 800+ sites, one by one, and check that it is correct. Following is the specific field I'm looking for in this example.
Thank you in advance for any and all guidance you may be able to provide.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@bkraut, I think you’re going to need to get your head around APIs. You can get the timezone with the Get Network endpoint, https://developer.cisco.com/meraki/api-v1/#!get-network. I reckon rather than checking 800+ networks manually, spend the time doing the DevNet Python introduction, and the DevNet Meraki Dashboard API introduction. You’ll learn some new skills and it will be more fun.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@bkraut : Check this out of it helps
https://developer.cisco.com/meraki/api-v1/#!get-network-alerts-settings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for that. I'm not quite to the level of DevNet API solutions at present, but definitely looks very useful in future. I am grateful for your taking the time to respond.
Have a great day.
Bob K
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@bkraut : API is the best way to do that , good luck buddy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks mate, reading/learning about it on DevNet now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Not for that particular field that I am aware of.
