Is it 27.6 or is it 26.9?
RBECK_CLPUD
When I look at an AP (MR32/MR33) screen, it tells me that the firmware is up to date and that it is v26.9.  When I look at the dashboard, Organization, Firmware Upgrades, All Networks, it tells me that the AP's are up to date and running v27.6.
Which one do I trust?
Mr32 can not run 27 it will stay on 26.x
If you look at a Mr33 it should be on 27.x
3 REPLIES 3
RBECK_CLPUD
Thanks!  We have some locations that started with MR32 and then got augmented with MR33 as the solution worked.  There are a couple of MR72's at another location.  I will look at them as well.
MUCH appreciated.
KarstenI
Perhaps what caused the confusion:
On the "Firmware Upgrades" page you do not see what firmware the devices are running. It only shows the firmware-version that should be used if the devices are capable of this version.
