We have recently undergone the process of converting our MX65s from Passthrough mode to NAT mode and in so doing we have broken communication between certain devices. For instance, each MX65 has a VLAN for Meraki Mgmt (VLAN 30 for APs, WIPS) and wireless clients (VLAN 40). In passthrough mode, Operations was able to communicate directly with APs and WIPS on the Mgmt network (from Data Center -> Local Mgmt VLAN). After converting they cannot. In passthrough mode you're allowed to configure rules Inbound and Outbound. In NAT mode you can only configure Outbound rules and under "Inbound" it just states: "Inbound traffic will be restricted to the services and forwarding rules configured below." The rule we have for Mgmt VLAN, under the "Outbound" section, is:
Allow Any-Proto Src-Mgmt-Net Src-Port-Any Dst-Any Dst-Port-Any
Do I also need to create another rule like this (reverse of the first rule)?
Allow Any-Proto Src-DC-Nets Src-Port-Any Dst-Mgmt-Net Dst-Port-Any
I really don't get the significance of the term "Outbound" in the case where the mode changes from passthrough to NAT. Outbound in relation to what? I don't get why it changes the behavior of the "Inbound" rule section under Security Appliance -> Firewall
