Find External IP Address
DarkMatter
I have a PC connected to a Meraki and want to find the external IP address that I would use to connect to it over the internet by something like RDP.  Where do you find the external IP of a device in the Meraki Dashboard?
Inderdeep
@DarkMatter :
Go to Organization/Overview.  Make sure "Hide table" is not ticked. Click on the arrow to expand the table. Go to the Devices tab.  Click on the + to add the columns "Public IP" and "Uplink IP (Port 1)".  You can add the second port as well if you want. Search for MX.
Regards/Inder
www.thenetworkdna.com
Inderdeep
@DarkMatter :
Regards/Inder
DarkMatter
Thank you very much!
I hadn’t noticed that there were 3 tabs across the top.
Inderdeep
@DarkMatter : Good luck !
Regards/Inder
