Features limitation with Template
StevePF
Anyone came across a list of features that is not compatible with template?
We start questioning the use of templates and if we would be better off with a tool like Bondless Digital to manage our devices.
Thanks,
Steve
2 Replies 2
- Configuration templates cannot be used on networks with Systems Manager.
- Templates are less effective if your networks have significant variations. Some settings can be overridden per site, but extensive differences can be challenging.
- All networks tied to a template must run the same firmware version. Updating the firmware on the template applies it to all attached networks.
- When binding a template, local settings like IP addresses and DHCP configurations can be lost unless specifically preserved.
Managing Multiple Networks with Configuration Templates - Cisco Meraki Documentation
Solved: Templates & Cloning - The Meraki Community
Implementing Templates - The Meraki Community
Inderdeep
