Extreme use of RAM on Mac OS Safari
Haertie
When I use the dashboard with Firefox, Edge, or Safari, the memory usage is extremely high. After 10 minutes of use, I have 3-4 gigabytes of RAM. The same behavior occurs on a Windows PC. It only works normally when using Google Chrome. Is the dashboard optimized exclusively for Chrome?
20 Replies 20
rhbirkelund
Yeah, I've also been noticing the same. For the last few weeks, I've seen my dashboard pages having reloaded due to excessive memory usage. Rather annoying when having to have multiple tabs open during troubleshooting.
I see the same on the latest version of Safari on MacOS 18.5.
Haertie
It affects not only Safari on Mac, but also other browsers and Windows. Only Google Chrome seems to be unaffected, which is strange.
It has worked well for me, without any problems.
RWelch
Glad @Haertie to see your post as I thought it was the shard that my dashboard sits (exist).  And glad to see @rhbirkelund finding the same.
Glad it's not just me that it's happening to.
BlakeRichardson
@Haertie does the amount of memory fluctuate based on what part of the dashboard you are viewing, I would think that viewing MV content would use more resources that simply viewing the network clients page.
As a matter of interest, what happens if you disable some of the cookies, like the performance cookies (scroll to the very bottom of the page to find this)?
Personally, I have disabled performance and targeting cookies.  I posted about this a while ago, but on my machine using Chrome developer tools, I measured the performance, and it was FASTER with these cookies turned off.  I never bothered checking memory usage.
Haertie
@PhilipDAth
Unfortunately, these cookies have no effect on memory usage. I think the developers are using some technology that is only properly supported by Google Chrome. I even have the memory problem with Edge (Windows and Mac OS), even though this browser is based on Chrome. We have a fairly large environment with many devices, and I've only been experiencing this behavior since Meraki started working on the new dashboard. I didn't have these problems before. Anyone whose dashboard feels slow should keep an eye on their memory usage. I don't understand why the developers don't notice this. Maybe they only use Chrome.
Have you tried updating your browser?  Perhaps it is a browser bug.
Haertie
It would be nice if it were that simple. I've tried all of that, and the problem isn't limited to one browser. I suspect it's related to a specific function in the dashboard, which would explain why it doesn't affect everyone.
This sounds more like a Safari issue than a Meraki issue.  It appears that the browser is experiencing a memory leak or struggling with memory management.
JGreen1280
I am a Windows user and have the exact same issue. Chrome, Firefox, edge they all do the same. I was actually just complaining about it to my Meraki TSA last week.
I also experienced the issue on my Android phone. I have not confirmed that it's RAM utilization but the phone pretty much locks up till I close the dashboard.
Here's how I reproduce, first of all the dashboard is sluggish, extremely slow and painful. When I select a site with access points, and I want to view the list of access points it can sometimes take minutes to load the list of access points even if there's only three.
When I click on an access point, the page takes 10 to 12 seconds just to load and as soon as it loads it refreshes and you have to wait again.
With the access point page open, it's something going on with the live graphs and objects that connect to the device or show you live connections and utilization. This somehow is what I think is causing the issue.
This occurs on the old version, and the new version of the page, but is more stable in the old version.
Generally when working on issues at a location, I may have to open up that live view page for three different access points at the same time, sometimes four or five. Once you get one or two of them open, my RAM utilization will go from 9 gigs utilized all the way up to 15. It will completely max out.
Thinking that it was a problem with my machine, I tried it from another machine, fresh build of windows on a virtual machine and it has the same issue. When I open the page on my Android phone the browser pretty much froze and locked up, so I'm not sure why some are seeing this and others aren't, but I'm definitely seeing it across all devices I use to access dash.
My personal Meraki account is on shard n17, and my large corporate account is on shard n45. The issue is consistent on both of them. But it seems to be worse on n45.
Haertie
I would like to revisit this topic. After many weeks of testing and trial and error, I am quite certain that the developers at Cisco-Meraki are developing the dashboard exclusively for Chrome-based browsers.
I have tried pretty much every browser available for weeks on Mac OS, Linux, and Windows, and my conclusion is that I have the memory problem everywhere except with Chrome-based browsers. Last week, I attended a Cisco Meraki training course and was able to use a dashboard there. The result was the same.
With Chrome, Edge, Brave, Chromium, etc., the dashboard runs relatively well and the memory consumption is quite acceptable. Usually no more than 1.5 gigabytes of RAM. All other browsers go crazy. Safari, Vivaldi, Firefox, and various smaller browsers all have this problem. Incidentally, the operating system plays no role in this.
Dear developers at Cisco Meraki. If you happen to be reading this. If that's the case, then just write it down. “Chrome-based dashboard only.” Then at least customers know what's going on and don't have to spend a lot of time troubleshooting.
In my opinion, it's just bad if you can't manage to program something like this for every browser. The main thing is blue bars and colorful bells and whistles.
CarolineS
Community Manager
Community Manager
Hi @Haertie -
I spoke to a couple folks here at Meraki about this, and they suggest you open a ticket so you can provide more details and can work directly with someone in support to troubleshoot.
Thank you!!
- Caroline
P.S. Here is the info on the ways to open ticket, should you need it: https://documentation.meraki.com/General_Administration/Support/Ways_to_Contact_Meraki_Support
Caroline S | Community Manager, Cisco Meraki
Haertie
Hello, thank you for this recommendation, but Meraki's support is obviously on par with a one-man operation.
After a month, I have nothing but hot air. That's why I want to try again here.
Since the problem won't leave me alone, I've tried a few things. In doing so, I noticed something interesting. When I activate the “Brave Shield” in the Brave browser (Chrome-based), it behaves exactly like Safari and causes extreme memory usage after a while.
If I turn this off, everything works great and memory usage remains within the normal range even after prolonged use.
Since Safari uses some mechanisms that block tracking and advertising, I could imagine that being the cause. It's just a suggestion, but maybe a developer reading this will be able to figure it out.
Maybe someone else who has the same problem can try this too.
You just gave me an idea.
Go to the very bottom of the Meraki Dashboard, any page, and click on "cookie preferences".
Disable both "Performance" and "Targeting" cookies.
I don't have the RAM issue - but for me this makes the Meraki Dashboard much more snappier.  You don't need a stop wach - it is very noticable.
Haertie
Thanks for the idea, but I always have cookies enabled. Unfortunately, that's not the problem.
Try disabling them.  These two in particular.
Haertie
Sorry about that last sentence. I meant disabled, not enabled. 😉
I've been doing that for months. I also just noticed that since yesterday, the link for cookie settings is at the bottom right and no longer opens. Let's see if it's just another temporary bug.
AadamH
Confirming the experience on Safari @Haertie
I thought my laptop was finally toast. It's been a miserable number of weeks of this
Chrome is the only one immune...
Safari: CPU jumps to 298% and 7+GB RAM usage for a single instance/tab of Meraki dashboard.
This is crazy.
CarolineS
Community Manager
Community Manager
Hi @AadamH -
Thank you!!
- Caroline
