Does Meraki slow down the speed during the grace period ?
Thihan
Does Meraki slow down the speed during the grace period?
5 Replies 5
Mloraditch
I have never seen any documentation that reflects this or ever experienced this on the many many times one of my orgs has been in grace period.
So I'd have to say you are experiencing some sort of coincidence
Ryan_Miles
Short answer, no
DarrenOC
I’ve seen many customers networks hit the grace period and not one has complained about the network being throttled.
Balensays
No, Meraki doesn't intentionally slow down the speed during the grace period. The grace period typically refers to the time when a device is being registered or when a firmware update is in progress. During this time, network performance may be temporarily affected due to the device not being fully functional yet or the update process consuming resources, but there's no throttling or intentional slowdown by Meraki.
If you're noticing a significant drop in speed during this period, it might be worth checking for other factors, like network congestion, bandwidth usage, or device configuration issues.
Ryan_Miles
That is not what grace period means
