Difference between Client usage and Client detailed usage
roOl
I've difference on client usage and detailed client usage.
Can you help me understand those values ?
roOl
Hey,
meraki support tell me the issue is now fixed.
7 Replies 7
Client usage is the sum of Download and Upload, Client detailed usage separates the two.
You can add that you will see that it makes sense.
Or you probably applied some filter wrong.
roOl
Hey alemabrahao,
total value is around 33Go when in the detailed view, value is 1.6To
Am I missing something ?
Does the detailed view value change if you set the range to 2 hour?
I think that 1.6Tb is from the 2 days active time. Not from 24h
roOl
Hey WW,
yes, value changes when I change the range ( device is currently unplugged, so I dont have value on the last 2 hours)
yet, if I follow your logic, for this device in 39 days I have a 29To usage, when usage shown for 30 days is only 620Go. I dont think adding those 9 days would close the gap.
roOl
Hey,
mrhammer
up
