I've difference on client usage and detailed client usage.
Can you help me understand those values ?
Solved! Go to solution.
Or you probably applied some filter wrong.
Hey alemabrahao,
total value is around 33Go when in the detailed view, value is 1.6To
Am I missing something ?
Does the detailed view value change if you set the range to 2 hour?
I think that 1.6Tb is from the 2 days active time. Not from 24h
Hey WW,
yes, value changes when I change the range ( device is currently unplugged, so I dont have value on the last 2 hours)
yet, if I follow your logic, for this device in 39 days I have a 29To usage, when usage shown for 30 days is only 620Go. I dont think adding those 9 days would close the gap.
Hey,
meraki support tell me the issue is now fixed.
up
