Deploy SSID on others networks
gerardgorrion
Hi all,
Currently we have some combined networks on meraki dashboard. One of this network have a new SSID (configured with radius to login users) and we want to add this SSID on others networks, if is possible without create a new network or delete current configuration, only add this radius SSID.
It is possible?
Thanks and regards,
7 Replies 7
jdsilva
No. You will have to manually add the new SSID to every network you want it in. Or, you can use the API to add it to the networks you want to.
There's no "copy ssid between networks" functionality in the dashboard.
Did I understand your question correctly?
What is API and how can I use it?
kYutobi
Not too sure what you're trying to ask but if you mean moving an SSID to another network that won't work. You can however just copy the same config if your other networks reach the RADIUS server.
Enthusiast
I want to copy the SSID without manually config on all networks. Thanks,
SoCalRacer
I believe if this is in the same org then a network template would work.
https://documentation.meraki.com/zGeneral_Administration/Templates_and_Config_Sync/Managing_Multiple...
SoCalRacer
I didn't notice the combined networks referenced, sounds like API is the best bet then.
