Delete Dashboard Account
pdeleuw
Hi all,
is it possible to delete a dashboard account? This would be helpful if an administrator leaves the company or something like that.
Best regards
Peter
7 Replies 7
DarrenOC
If an Admin leaves or you need to revoke access then you can remove that person as an Administrator from your Organisation.  You can’t delete someone else’s Meraki account
BlakeRichardson
You should find this useful.
https://documentation.meraki.com/General_Administration/Managing_Dashboard_Access/Managing_Dashboard...
pdeleuw
Thank you. I know how to configure admins in dashboard. I know to adjust the permissions, I know how to delete an admin in an org. Remember: The admin account belongs to our company. So it is not "someone else's" account. It is an e-mail address belonging to our company. There should be a solution to delete an obsolete account. Beside that: It is not possible for me to delete my own account, too.
RWelch
Have you tried Call Me Now
mlefebvre
It sounds like you should consider transitioning to SAML for dashboard access
If you have access to the email, you can control it.
GreenMan
Meraki Alumni (Retired)
As CMR suggests, if it's your email, simply change the associated password and check out availability of any 2FA tools.   I would recommend SAML too - in fact;  user-specific accounts more generally.   How would a problematic change be attributable to one admin, if you needed to follow disiplinary (even criminal) processes, if there's no specific accountability?
