Dashboard time errors
Has anyone else noticed that events on the timeline in the dashboard do not correspond accurately with what happened?  As an example, I have just upgraded an MX and on the dashboard I see the below:
However, I also log the actual availability of the services that need this device to be up and they show that it was down from 10:08 to 10:10.
It appears that the dashboard times are when the events have been processed and not when they occurred...
5 Replies 5
Bizarrely the passive MX in the HA pair shows (near enough) the correct times, which were 10:23 to 10:25...
Ryan_Miles
A MX HA pair will upgrade each unit separately so I would anticipate different times. Although, I would expect the opposite then of what you posted as the primary should upgrade first.
Ryan
@Ryan_Miles the primary did upgrade first, the point was that the upgrade of the primary actually occurred 3 minutes before the timeframe reported in the dashboard.  The secondary upgrade times match.  Is this expected?
Ryan_Miles
I've upgraded MX HA pairs for years (as run now and scheduled) and honestly never looked at the connectivity bar to see if the times match.
Ryan
DarrenOC
@cmr is very thorough and I’d trust what he’s saying. If it’s broken or not right, he’ll spot it.
