Hi @BlakeRichardson,
Sorry to hear about the session timeout and log out issues you're experiencing.
Is the issue seen across several different browsers and when using incognito or private browsing mode?
To best help determine the root cause of the issue, would you be able to open a case with Meraki Support?
-- As these types of issues generally require some investigation and data gathering (i.e. current dashboard settings and configurations, email address(es) of the administrator(s) affected, possibly gathering a HAR capture within the browser, etc.).
Additionally, if you're able to provide a timestamp of when the continue button last failed to extend your session along with the email address of the affected account, a support representative should be able to review if any specific error may have logged on the backend.
To raise a case with Meraki Support, please navigate in the dashboard to Get help > Cases > New Case or by following the steps provided in the Contact Cisco Meraki Support document here.
Best,
Feli
If you found this post helpful, please give it kudos. If this answer helped solve the issue, click "accept as solution" so that others can benefit from it.
