How to move Duo authentication account from one mobile to another?
Varchola
I'm using Duo account for Two-factor authentication to Meraki dashboard and I need to move it to another mobile, but I can't figure out how to do it in My Profile in Meraki dashboard.
Should I just delete Duo account on my current mobile? Will it automatically recognize that and give me option to set up new Two-factor authentication with new mobile?
You don't need to delete the Duo account on your current phone, just add the new slide.
In fact, I don't think this would even be a question for the Meraki community. See this guide.
https://guide.duo.com/add-device
Ryan_Miles
Meraki Employee All-Star
If you're logged in you can go to your profile, disable 2FA, then reenable it and it will show a new QR code to scan in your Duo app.
This.
