Dashboard problems?
NolanHerring
Dashboard problems?
My team and I have all been running into issues with the dashboard loading. Found this link on Reddit that seems to confirm it isn't just us.
https://www.reddit.com/r/meraki/comments/1hvwyg4/issue_with_the_meraki_cloud_when_trying_to_open/?rd...
I didn't see a post here so figured I would add it in case anyone else like me is looking for validation.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
6 Replies 6
RaphaelL
I haven't encountered the issue yet.
Is it only with a specific page ( a.k.a wireless like in the reddit page ?)
Ryan_Miles
There is a specific issue with the AP detail page loading for SAML network only admins. Aside from that I've not heard of broader issues today.
Are you specifically seeing the issue with the AP detail page or other pages?
NolanHerring
Yeah so this seems then to be exactly our issue. Only seems to be related to the AP page. We are using SAML.
TwitterLinkedIn
Ryan_Miles
Workaround at the moment is when the page loads the "old" version click the ESC key to stop the page loading. Then you should be able to navigate around the tabs and between APs. If you have the device health tab don't click that or it will launch the "new" version and break the page again.
NolanHerring
Thank you Ryan. I'll forward this to my team for the interim.
TwitterLinkedIn
That page is also s-l-o-w to load.
