Current Firmware Status Reporting
PJ51182
I have been asked to generate a report on a large number of organisations.  The main aim is to show that all of the firmware is up-to-date and therefore compliant.
Has anyone else had to do a similar exercise and found an easy way to do this?  At the moment the only way I can see to do this is to go to each origination and then to the firmware upgrade tab.
A scheduled report would be ideal but I can't see a way to generate one with the relevant info on the status of the kit.
I thought perhaps the API would be an option?
Cheers
Phil
2 REPLIES 2
RaphaelL
Hi ,
I would really go with the API. There is an endpoint for the firmware versions but it is kinda ''bugged'' or not giving the desired info.  I have a ticket opened about it.  ( https://developer.cisco.com/meraki/api-latest/#!get-network-firmware-upgrades )
Anyway , you can pull the device status and you will get the firmware version. Hope that helps !
BlakeRichardson
Yes API would be your best option otherwise you will be doing an awful lot of navigating in a web browser.
www.btr.net.nz
