Are you able to login now? I'm thinking yes based on your screenshot. When logged in go to your email in the upper right, click My profile, and on that page you should be able to disable 2FA, save, then re-enable 2FA to get a new QR code.
![Screenshot 2023-11-02 at 9.06.56 AM.png Screenshot 2023-11-02 at 9.06.56 AM.png](https://community.meraki.com/t5/image/serverpage/image-id/33765iB6BB5F4DCE09CCA6/image-size/large?v=v2&px=999)
Just noticed you said it's enabled at your Org level. It does seem to then remove the off function as I noted at the user level. My thought would be disable it Org wide, then disable your own 2FA, set it back up, then enable at Org level again.
Or maybe run it by Support to see if there's another way I'm unaware of.
