We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hello
I`m trying to open a case for Meraki support regarding an issue I have with my MX (Showing many Events dropped).
Although I opened a case two times already, nothing is showing in the Dashboard.
Any idea what can be done?
Solved! Go to solution.
Did you get a email about the case?
Try view old version in the right corner, or try another browser.
If that doesnt work try call support
Didn`t get any email.
Tried to open the first case in the old version and the new versions. both didn't work.
Where can I get their phone number ? I could find it online
Ok was able to find their number
Thank you mate
