Auto delete self-registered users
We have a splash page for a BYOD/Guest wireless network that requires users to self-register an account in order to use.
Is there a way for the dashboard to auto-delete these accounts after a set time?
1 REPLY 1
Re: Auto delete self-registered users
@StoobyDoo I am afraid it is not possible. I don't think we can set up a timer so that the self-created accounts will be deleted automatically once the timer expires. Unfortunately, an API call is not available to delete users either. Please leverage the "Make a wish" button on the dashboard to request this feature. Hopefully, we can come up with something like this in the future.
That best bet, for now, would be to delete them from the user's page from time to time.
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
