Alert Time - less than 5 mins
GaryShainberg
All,
Has anyone had any success in getting our friends at Meraki to reduce the network alert times to less that 5 mins, which is the miinimum the systems allows ?
-Gary
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
Dylan_YYC
Not from the dashboard, but i think you can do something similar via SNMP if you want to set that up i suppose.
KRobert
Similar to what @Dylan_YYC said, we use SolarWinds Orion and SNMP to know when our Meraki appliances are down. You can be notified as quickly as every 10 seconds.
CMNO, CCNA R+S
Nash
Another SNMP monitoring option is Auvik. I work at an MSP that uses it at every client that's got a server. Integrates with the Meraki dashboard and handles the SNMP bits quite nicely.
GaryShainberg
Guys
Thanks and I am playing with PagerDuty and using WebHooks, but this is still with the 5 min limitation - I looked at Auvik but could not get it working, although it does look like it could work well.
I may have to persevere.....
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
