Is it possible to add a company logo to the Meraki dashboard?
Cole
I would like to replace the Cisco Meraki logo with a company logo in the upper left hand corner of the dashboard if possible.
CptnCrnch
The document states: „Dashboard branding options are only available to qualified Managed Service Providers. Please contact Cisco Meraki Support to check eligibility“
9 REPLIES 9
Cole
Thank you for sending this over. I have seen this document but I do not have the Branding option in my organization settings. Is there something I need to do in order to have that option?
CptnCrnch
Cole
As far as I know, I am not a Managed Service provider. Oh well, no big deal.
Thank you for all of your replies.
jdsilva
Doesn't hurt to all support and ask to get it enabled. Worst case they say not. Maybe they say yes... 🙂
Cole
I spoke with support and I am not eligible to have this option enabled.
Nick
That is a shame, you don't as you don't get..
But in this case that hasn't worked!
Cole
I made a wish. Maybe it will be granted. 🤞
jdsilva
I got your back.
