AUTOMATIC Firmware Upgrade?
ToryDavenport
Hi!
I am trying to research this topic but have not had much luck.
Is there a way to automate firmware upgrades? I know I can manually schedule upgrades, but that can be tedious as an MSP managing dozens of organizations.
QUOTE:
"Customers can now manage firmware for each network in their organization by selecting which firmware runs on which network, while still providing the automatic upgrade functionality for customers who don’t desire this level of control."
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design#...
What about the API?
Thank you in advance!
BrechtSchamp
You can setup an upgrade window for your networks. Then it'll just schedule the upgrades automatically. See Network-wide > General:
8 Replies 8
BrechtSchamp
ToryDavenport
I missed this when I looked in that section.  Thank you @BrechtSchamp !
BrechtSchamp
You're welcome sir :).
TylerK
Hello, I also work for an MSP and am running into this issue, however, we have those configurations set and we still see that there are updates available even with the window set.
Any idea on how I can track down why this may not be working properly? Log files,etc.
JHatem
My gear is configured as the solution suggests, however it doesn't seem to be working as expected.
My APs show that there is an update available.  I got here from Organization, Firmware Upgrades, All Networks.
However, from Network Wide, General, my APs are configured to upgrade weekly.  See that the last successful run was in 2018!   I manually updated the switches Jan 8.
Lastly, if I look at the AP itself, it claims to be up to date.
Some helpful guidance is appreciated.  Thanks!
Tim-Groeneveld
I set it up like this for a few years now, but it just does not work. The only difference with your configuration is that I don't want to try beta firmware.
Currently I check in every half year or so and schedule an upgrade manually.
The firmware is only upgraded when the existing firmware is either warning or no longer a stable release.  If you enable betas then the same applies to replacing a beta that is no longer current with the current one.
Tim-Groeneveld
That explains it, thank you!
(I spent hours trying to finf the hidden button that I had to press..)
