Notice the section at the bottom of this post with my name & job role:
Caroline S | Community Manager, Cisco Meraki |
@merakicaroline
That's my community signature. It shows up below each of my community posts. One neat thing about signatures is that when they're updated, they update across all of your posts.
How do I get a signature?
You can easily set up your own community signature.
- Click on your name in the upper right, then "My Settings"
- From the My Settings page: Personal > Personal Information
- Fill in the Signature field and click Save.
Go check out one of the posts you've made and you'll see your signature at the bottom.
What should / shouldn't be in my signature?
Feel free to add your name, a link to your company and/or social links, and a small bit of personal or professional information. You can also politely request kudos. Any other links or text must respect our community guidelines and should not be used as advertisement. Feel free to reach out to me (via this thread or private message) if you need further clarification.
You can also use simple HTML tags (a, strong, br, span/div w/ a "class" attribute, etc); users at "Here to help" status or above get a bit more freedom with HTML tags/attributes.
I want a signature that looks just like yours!
I'm flattered! Here's the code (obviously, use your own name, role, and social link).
Caroline S | Community Manager, Cisco Meraki | <a href="https://twitter.com/merakicaroline" target="_blank">@merakicaroline</a>
<br >
<i>Found this helpful? Give me some Kudos! (click on the little up-arrow below)</i>
Cheers!
