I created a new port-channel and tried to attach two interfaces to it, however I received the error message below:
Command rejected: conflicts with IPv6 Snooping (FHS)
In order to attach the interfaces to the port-channel I had to remove the following line from each interface:
no device-tracking attach-policy MERAKI_POLICY
This is just information in case anyone else comes across the issue, and while it did allow me to attach the interfaces to the port-channel, it wouldn't allow me to add the device-tracking command back into each of the interfaces after they were linked to the port-channel.
Is It a Maraki switch or catalyst switch?
Have you tried to run the command default on interfaces?
I haven't tested that, but I can try that out tomorrow on an unused port.
The switches are Catalyst 9300s.
Thanks @DevOps_RC for the workaround.
I have the same problem here with a 9300 running 17.04.
Ports that were already in a port channel before the on-boarding seems fine but i can't add new ports.
Do you have an update on this issue ?
I had he same issue with 17.9.4a on one of my 9300 switches. I defaulted the interface and than had no issues adding it to the port-channel.
you need to
- remove policy from ports
- add ports to port-channel
- add policy "device-tracking attach-policy MERAKI_POLICY" to port-channel
example:
interface TwentyFiveGigE1/0/10
switchport trunk native vlan 230
switchport mode trunk
channel-group 1 mode active
end
interface TwentyFiveGigE2/0/10
end
interface Port-channel1
end
otherwise the Meraki dashboard not will detect the ports and VLAN configuration and you can have a mismatch VLAN on port or other cosmetics errors in Meraki dashboard
