We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Supports 5G SA but otherwise seems the same as the 51. Not on the data sheets yet for a more detailed comparison...
https://meraki.cisco.com/en-uk/product/cellular/integrated-antenna/mg52/
https://documentation.meraki.com/MG/MG_Datasheets/MG52%2F%2F52E_Technical_Specifications
Solved! Go to solution.
eSIM is the other major feature of the MG52
@Ryan_Miles to be fair I forgot that the MG51 didn't support eSIM!
No ones going to mention that the first 30 data of data are on Cisco?
You just did 😛
