May 8 2024
1:08 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
May 8 2024
1:08 AM
Meraki 51 provide wireless access to users like access point
Kindly advise about what should be reply with regards to Meraki gateway MG51
- Does the device support wifi signal?
- The second SIM is for failover, can it be configured so device will use/switch to the SIM with best performance/speed?
- Is the MG51-e with external antenna necessary for deployment on transport trucks that travel to remote area or is internal antenna model sufficient?
Solved! Go to solution.
May 8 2024
1:22 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May 8 2024
1:22 AM
1) No
2) No
3) I would assume that the MG51E with the Omni Antennas (included and don't have to be ordered separately) can service this use-case better than the MG51 as the truck will likely turn directions, and the Omni works in all horizontal directions.
2 Replies 2
May 8 2024
1:22 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May 8 2024
1:22 AM
1) No
2) No
Jun 3 2024
8:09 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun 3 2024
8:09 AM
Keep in mind that the MG51 is not certified for vibration or mobile environments, mileage may vary.
