Move MG52 to another network
GregasG
I have a Meraki MG52 cellular gateway that I am currently evaluating.
I've added it to a test network in our organization and it seems to be working fine.
Is there a way to remove the gateway from one network and add it to another one?
I can do this with access points and Security appliances, but have not found where to do this with the MG52.
What am I missing?
Thanks in advanced for any help.
Go to cellular gateways > monitor > cellular gateways
There you can select the checkbox in front of the gateway name.
Above the box should be a edit button
6 Replies 6
RWelch
If you are need it moved from the test network to a different network or organization you would need to move it in inventory.
In the Dashboard go to Organization > Configure > Inventory and check (select) the device you need to move and on the RH side select ACTIONS to Change network assignment, organization, remove from organization.
GregasG
Thanks!!
Don't know how I missed that earlier.
rsage_voda
Hi what has been your experience of the MG52. Considering it for a customer project.
GregasG
Hard to say as we only have one deployed and it is being used as a backup internet connection in case our primary service goes down.  We have not had any of those incidents at this location yet.
That being said, during our testing it worked pretty well at our location in Chicago -- it obviously depends on the signal strength/quality from the cell provider.
ArTiCo
Thank you very much to comment your experience. It's very helpful for us. We have a strongest signal from the cell provider. I think the MG is a very nice solution and integrates perfectly with all Meraki system, evidently.
I give you my first Kudo. Thank you.
