Move MG52 to another network
GregasG
I have a Meraki MG52 cellular gateway that I am currently evaluating.
I've added it to a test network in our organization and it seems to be working fine.
Is there a way to remove the gateway from one network and add it to another one?
I can do this with access points and Security appliances, but have not found where to do this with the MG52.
What am I missing?
Thanks in advanced for any help.
Go to cellular gateways > monitor > cellular gateways
There you can select the checkbox in front of the gateway name.
Above the box should be a edit button
RWelch
If you are need it moved from the test network to a different network or organization you would need to move it in inventory.
In the Dashboard go to Organization > Configure > Inventory and check (select) the device you need to move and on the RH side select ACTIONS to Change network assignment, organization, remove from organization.
GregasG
Thanks!!
Don't know how I missed that earlier.
