- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MR84 in Alerting Mode
Hey everyone! My MR84 is in Alerting Mode and I'd like to get it to Online Mode. When I click on my AP in the Meraki Dashboard it displays, "Uplink IP address in conflict with another device". Could this be part of (or all of) the problem?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
So almost certainly it has an IP address conflict with something else. If it is a small site with 1 or 2 switches (for example) arrange a time to power cycle the switches.
This will make every device DHCP for an IP address again and will often solve the issue.
If you are using Windows DHCP try enable DHCP conflict detection to avoid it giving out IP addresses already in use.
http://www.itgeared.com/articles/1124-using-conflict-detection-in-dhcp/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Is the MR84 receiving a DHCP address or are you manually assigning it? By chance could you change the address to something else to make sure it isn't a duplicate?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It is receiving a DHCP currently, and seemingly no matter what I do it won't change the IP. I've tried static and it still just keeps the same address and says configured by DHCP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are you able to log into via "local status page"? You can change configurations to it so that you know you're making local changes and it's applying.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
In case you‘re asking „what‘s the local status page“:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks @CptnCrnch 👍 I should've provided a link instead of speaking so vaguely. 😂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@PhilipDAth If all else fails that is something we are going to do, but it wouldn't be convenient to do until after hours, so I'm going to keep on trying to get it operational before then. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
After connecting to the Meraki's SSID, I went to my Meraki's IP Address and it took me to this page.
Where do I go from here?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Update another error message has just popped up stating: "This device is using a DHCP IP address from VLAN 0 instead of using configured VLAN 1."
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you have a management vlan for all your meraki devices? If yes, set that as management vlan at switch>switch settings.
On your switchport connecting to the AP set your management vlan as native vlan. At your AP management ip set it to Dhcp and leave the vlan field empty
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
IP-Address conflict with your VMWare-Server. Change the address of the server or (maybe easier) of the accesspoint.
