MG51 SIM card PIN ?
Jyrki_Halonen
MG51 SIM card PIN ?
I have MG51 with one SIM installed, but can't connect to Cellular network.
Local status page says:"Status: PIN_required".
How can I enter PIN code to the card?
Another option can be to put the SIM into a phone, and then disable the SIM PIN requirement, and then put it back into the MG51.
5 Replies 5
GreenMan
I couldn't find such option from the MG51 local page.
With hindsight, you're right, sorry    (I only have an MG21 personally, where it is an LSP option).
I raised this with product line and it is planned for addition to MG51 (and MG41) at some point, but with no fixed timeframe for availability, just now.   I have asked the team for an update, which I'll share when I can.
This is what I did and got it working, thanks.
