Meraki MX Cable
解決済み
Kiki
Meraki MX Cable
location In Japan, there is no MA-PWR-CORD-JP option in the datasheet or ordering guide, but CCW says MA-PWR-CORD-JP is available for MX, which cable should I choose? US or JP?
https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/MX67_and_MX68_Datasheet
>配件
MA-PWR-CORD-US 1x AC Power Cable, US plug
MA-PWR-CORD-EU 1x AC Power Cable, EU plug
MA-PWR-CORD-UK 1x AC Power Cable, UK plug
MA-PWR-CORD-AU 1x AC Power Cable, AU plug
1 件の受理された解決策
Soichiro-Ono
For use in Japan, it is MA-PWR-CORD-JP. MA-PWR-CORD-JP is certified for use in Japan. This cable is to be connected to a Japanese commercial 100 V environment. The specifications are not intended for other voltage bands, such as the 200 V commercial environment in Japan. The shape is similar to MA-PWR-CORD-US.
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
元の投稿で解決策を見る
2件の返信2
It is just a normal IEC C13 to local AC plug lead. You can use any lead from a local store.
Soichiro-Ono
ラベル
