what is the behaviour of meraki ap when connect to a non dhcp enabled network
Keshavm
what is the behaviour of meraki ap when connect to a non dhcp enabled network and static ip assigned to it
RaphaelL
Same exact behavior that it would be on a dhcp enabled network.
Keshavm
when we connect new ap to poe switch and on a switch dhcp is disabled we accces local staus page and give static ip to ap then  i want to know behaviour of ap ? how it communicate to cloud and is it broadcast ssid ?
It starts trying to connect the cloud via the configure ip gateway. If it cant connect the meraki cloud it cant get its config and won't work properly.
GreenMan
Meraki Alumni (Retired)
You will also need to configure the AP (and the upstream network) to be able to reach public DNS, to resolve the Meraki cloud IPs.
