what is the antenna connection type on MR46E Please
Radarspeed5
can someone inform of the correct antenna port type on the meraki MR46E model please? am i right in thinking it is RPTNC plug?
That's what I said in the previous post.
6 Replies 6
Antenna
  • List of compatible antennas: MA-ANT-3-A6/B6/C6/D6/E6/F6
  • Individual antenna elements for each radio
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR46E_Datasheet
https://meraki.cisco.com/lib/pdf/meraki_datasheet_MA-ANT-3-A.pdf
Radarspeed5
Just as i thought but i couldn't find that info when looking at the data sheet for the access point, didn't think to check the antenna documentation though. don't want to be ordering incorrect antenna
GIdenJoe
It is in fact RP-TNC.
You can check this for example with external vendors like Acceltex where they have a nice way of listing compatible AP's with their antennas 😉
GIdenJoe
I know, and I added that other antenna vendors also list those if you want to reference those antennas with the AP's.  I'm not trying to detract from your response.  I'm sorry if you would feel that way.
No no, it's all right, it's not a problem. 😊
