- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
syslog: disassociation reason
When I look at the wireless syslog, it looks several types of reasons exist for the disassociation event. See below examples. Can you give a short description about each number of the reasons ? At least, I got 2, 3, 6, 8, 15, 23, and 34.
2023-06-26 00:18:07.319045 1687706287.319044786 MR36_xxx events type=disassociation radio='0' vap='1' client_mac='46:C4:0C:xx:xx:xx' band='2' channel='1' reason='23' da_vendor='none' duration='10.080828475' auth_neg_failed='1' is_8021x='1' identity='anonymous@apple.openroaming.net' aid='108276xxxx'
2023-06-26 00:30:02.894287 1687707002.894287393 MR36_xxx events type=disassociation radio='0' vap='1' client_mac='46:C4:0C:xx:xx:xx' band='2' channel='1' reason='8' da_vendor='apple' da_reason='3' da_subreason='0' instigator='2' duration='6.292869157' auth_neg_failed='1' is_8021x='1' identity='anonymous@apple.openroaming.net' aid='82611xxxx'
Solved! Go to solution.
- Labels:
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
802.11 Association Status, 802.11 Deauth Reason codes
802.11 Association Status Codes
Code | 802.11 definition | Explanation |
0 | Successful |
1 | Unspecified failure | For example : when there is no ssid specified in an association request |
10 | Cannot support all requested capabilities in the Capability Information field | Example Test: Reject when privacy bit is set for WLAN not requiring security |
11 | Reassociation denied due to inability to confirm that association exists | NOT SUPPORTED |
12 | Association denied due to reason outside the scope of this standard | Example : When controller receives assoc from an unknown or disabled SSID |
13 | Responding station does not support the specified authentication algorithm | For example, MFP is disabled but was requested by the client. |
14 | Received an Authentication frame with authentication transaction sequence number | If the authentication sequence number is not correct. |
15 | Authentication rejected because of challenge failure |
16 | Authentication rejected due to timeout waiting for next frame in sequence |
17 | Association denied because AP is unable to handle additional associated stations | Will happen if you run out of AIDs on the AP; so try associating a large number of stations. |
18 | Association denied due to requesting station not supporting all of the data rates in the | Will happen if the rates in the assoc request are not in the BasicRateSet in the beacon. |
19 | Association denied due to requesting station not supporting the short preamble | NOT SUPPORTED |
20 | Association denied due to requesting station not supporting the PBCC modulation | NOT SUPPORTED |
21 | Association denied due to requesting station not supporting the Channel Agility | NOT SUPPORTED |
22 | Association request rejected because Spectrum Management capability is required | NOT SUPPORTED |
23 | Association request rejected because the information in the Power Capability | NOT SUPPORTED |
24 | Association request rejected because the information in the Supported Channels | NOT SUPPORTED |
25 | Association denied due to requesting station not supporting the Short Slot Time | NOT SUPPORTED |
26 | Association denied due to requesting station not supporting the DSSS-OFDM option | NOT SUPPORTED |
27-31 | Reserved | NOT SUPPORTED |
32 | Unspecified, QoS-related failure | NOT SUPPORTED |
33 | Association denied because QAP has insufficient bandwidth to handle another | NOT SUPPORTED |
34 | Association denied due to excessive frame loss rates and/or poor conditions on current | NOT SUPPORTED |
35 | Association (with QBSS) denied because the requesting STA does not support the | If the WMM is required by the WLAN and the client is not capable of it, the association will get rejected. |
36 | Reserved in 802.11 | This is used in our code ! There is no blackbox test for this status code. |
37 | The request has been declined | This is not used in assoc response; ignore |
38 | The request has not been successful as one or more parameters have invalid values | NOT SUPPORTED |
39 | The TS has not been created because the request cannot be honored; however, a suggested | NOT SUPPORTED |
40 | Invalid information element, i.e., an information element defined in this standard for | Sent when Aironet IE is not present for a CKIP WLAN |
41 | Invalid group cipher | Used when received unsupported Multicast 802.11i OUI Code |
42 | Invalid pairwise cipher |
43 | Invalid AKMP |
44 | Unsupported RSN information element version | If you put anything but version value of 1, you will see this code. |
45 | Invalid RSN information element capabilities | If WPA/RSN IE is malformed, such as incorrect length etc, you will see this code. |
46 | Cipher suite rejected because of security policy | NOT SUPPORTED |
47 | The TS has not been created; however, the HC may be capable of creating a TS, in | NOT SUPPORTED |
48 | Direct link is not allowed in the BSS by policy | NOT SUPPORTED |
49 | Destination STA is not present within this QBSS | NOT SUPPORTED |
50 | The Destination STA is not a QSTA | NOT SUPPORTED |
51 | Association denied because the ListenInterval is too large | NOT SUPPORTED |
200 |
Unspecified, QoS-related failure. | Unspecified QoS Failure. This will happen if the Assoc request contains more than one TSPEC for the same AC. |
201 | TSPEC request refused due to AP’s policy configuration (e.g., AP is configured to deny all TSPEC requests on this SSID). A TSPEC will not be suggested by the AP for this reason code. | This will happen if a TSPEC comes to a WLAN which has lower priority than the WLAN priority settings. For example a Voice TSPEC coming to a Silver WLAN. Only applies to CCXv4 clients. |
202 | Association Denied due to AP having insufficient bandwidth to handle a new TS. This cause code will be useful while roaming only. |
203 | Invalid Parameters. The request has not been successful as one or more TSPEC parameters in the request have invalid values. A TSPEC SHALL be present in the response as a suggestion. Not defined in IEEE, defined in CCXv4 | This happens in cases such as PHY rate mismatch. If the TSRS IE contains a phy rate not supported by the controller, for example. Other examples include sending a TSPEC with bad parameters, such as sending a date rate of 85K for a narrowband TSPEC. |
802.11 Deauth Reason Codes
When running a client debug, this code will match the ReasonCode from the output: "Scheduling mobile for deletion with delete Reason x, reasonCode y"
0 | Reserved | NOT SUPPORTED |
1 | Unspecified reason | TBD |
2 | Previous authentication no longer valid | NOT SUPPORTED |
3 | station is leaving (or has left) IBSS or ESS | NOT SUPPORTED |
4 | Disassociated due to inactivity | Do not send any data after association; |
5 | Disassociated because AP is unable to handle all currently associated stations | TBD |
6 | Class 2 frame received from nonauthenticated station | NOT SUPPORTED |
7 | Class 3 frame received from nonassociated station | NOT SUPPORTED |
8 | Disassociated because sending station is leaving (or has left) BSS | TBD |
9 | Station requesting (re)association is not authenticated with responding station | NOT SUPPORTED |
10 | Disassociated because the information in the Power Capability element is unacceptable | NOT SUPPORTED |
11 | Disassociated because the information in the Supported Channels element is unacceptable | NOT SUPPORTED |
12 | Reserved | NOT SUPPORTED |
13 | Invalid information element, i.e., an information element defined in this standard for which the content does not meet the specifications in Clause 7 | NOT SUPPORTED |
14 | Message integrity code (MIC) failure | NOT SUPPORTED |
15 | 4-Way Handshake timeout | NOT SUPPORTED |
16 | Group Key Handshake timeout | NOT SUPPORTED |
17 | Information element in 4-Way Handshake different from (Re)Association Request/Probe Response/Beacon frame | NOT SUPPORTED |
18 | Invalid group cipher | NOT SUPPORTED |
19 | Invalid pairwise cipher | NOT SUPPORTED |
20 | Invalid AKMP | NOT SUPPORTED |
21 | Unsupported RSN information element version | NOT SUPPORTED |
22 | Invalid RSN information element capabilities | NOT SUPPORTED |
23 | IEEE 802.1X authentication failed | NOT SUPPORTED |
24 | Cipher suite rejected because of the security policy | NOT SUPPORTED |
25-31 | Reserved | NOT SUPPORTED |
32 | Disassociated for unspecified, QoS-related reason | NOT SUPPORTED |
33 | Disassociated because QAP lacks sufficient bandwidth for this QSTA | NOT SUPPORTED |
34 | Disassociated because excessive number of frames need to be acknowledged, but are not acknowledged due to AP transmissions and/or poor channel conditions | NOT SUPPORTED |
35 | Disassociated because QSTA is transmitting outside the limits of its TXOPs | NOT SUPPORTED |
36 | Requested from peer QSTA as the QSTA is leaving the QBSS (or resetting) | NOT SUPPORTED |
37 | Requested from peer QSTA as it does not want to use the mechanism | NOT SUPPORTED |
38 | Requested from peer QSTA as the QSTA received frames using the mechanism for which a setup is required | NOT SUPPORTED |
39 | Requested from peer QSTA due to timeout | NOT SUPPORTED |
40 | Peer QSTA does not support the requested cipher suite | NOT SUPPORTED |
46-65535 | 46--65 535 Reserved | NOT SUPPORTED |
98 | Cisco defined | TBD |
99 | Cisco defined Used when the reason code sent in a deassoc req or deauth by the client is invalid – invalid length, invalid value etc | Example: Send a Deauth to the AP with the reason code to be invalid, say zero |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
0 | Successful |
43 | Invalid AKMP |
200 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the quick response! Well, 802.11 Deauth Reason Codes you listed looks the one. However, is it documented that the reason codes in the syslog can be referred to 802.11 Deauth Reason Codes ?
