We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
I have 4G LTE data networks at home if I buy a SD-WAN cloud router can I get the speed like fiber?Thank you and waiting for answers.
Solved! Go to solution.
Only if you connect a fiber ISP link.
If you connect LTE you get LTE speeds
Ok thanks 🙂
