Hello Guys,
am getting this error ( type='802.1X auth fail' num_eap='1' first_time='0.072863200' associated='true' radio='0' vap='0') while running a test to my mr53e. What could i be doing wrong?
Regards.
Solved! Go to solution.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...
Using a radius server?
Using Meraki Auth?
any more informations? 😉
using radius server.
but if i ping from my meraki access point am able to reach my windows radius server.
@Felix_Mugambi wrote:but if i ping from my meraki access point am able to reach my windows radius server.
And you are able to do the "Radius connection test" within the dashboard ?
MR ist configured in your radius server as well?
from the dashboard the test fails
you need to configure the mr on radius server?how?
