Good morning
I am trying to construct a meraki mesh.
Please answer the following questions.
1.
Is the same channel of the Gateway AP and the Repeater AP used for the mesh?
Also, is there a problem with the mesh link when the client uses the service in the Mesh frequency band?
2.
Gateway AP uses dual-band patch antennas and installs two repeater APs
1 Repeater AP 5 GHz Sector Antenna / 1 Repeater 2.4 GHz Sector Antenna
Is it possible to configure Mesh for Omni Antenna configuration of the remaining antenna?
Can the Gateway AP establish a Mesh Link at 2.4 / 5 Ghz at the same time?
3.
Is it working when there is another Meraki AP (other organization) near the Repeater AP after Mesh network configuration?
Is there an issue?
thank you
