I'm considering use some MR33 to found a mesh network, covering a place do not have wire ethernet access.
——ethernet cable——RAP---MAP--MAP………………MAP
I can see a description about the maximum mesh hop in the Mesh Deployment Guide (CVD):
There will be a throughput reduction (~50% reduction) with each “hop” in a mesh. It is recommended that a mesh network be designed for no more than one mesh hop from the gateway to client device.
But I can't find the actual maximum hops number of the Meraki AP. (for the Cisco Aironet AP the maximum mesh hops is 😎
So, what's the maximum mesh hops of the MR33 ?
Had someone setup a mesh network more than one hop?
Regards,
