What is the latest build for the MR 52 access points?
Solved! Go to solution.
I´m running beta MR 26.5
Release notes:
@WarrenForNOLA Yes Build 26 is a Beta release. Meraki beta releases are usually very good though plus the beauty with Meraki is you can rollback the firmware if you run into problems.
Release notes:
Thank you for the great input. How do I download the 26 build?
@NolanHerring - Do you have any 2.4ghz devices running on the MR52s? I had run into an issue with 26.3 and devices like wireless printers dropping and not reconnecting. No issues like that with my MR34s.
