best practises for MR installation
GregGood971
Hi everyone,
I would like to know if you have a document that informs about how we have to install an access point : what kind of wall? what kind of drilling ?
Everything that can help us to install MR in order to enjoy the best performance
Look at this:
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
5 Replies 5
Look at this:
GregGood971
thank you for the answer. It is very interesting. Regards
BlakeRichardson
If you are totally new to deploying wireless maybe seek the advice of a consultant this time around so that next time you know what to look out for.
If you Google "Meraki MRxx Installation Guide", where "xx" is the model you are using, you'll get detailed instructions.
For example, the MR36:
https://documentation.meraki.com/MR/MR_Installation_Guides/MR36_Installation_Guide
GregGood971
Thank you. I will use the information with those provided by @alemabrahao
