- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
auth server rejected the auth request problem
Dear All,
Would like to ask we encountered below issue, just wonder any configuration can be modify in meraki dashboard side rather than in radius side ? any help would be appreicated
Failed connection to SSID WiFi - internal on access point Office-5 during authentication because the auth server rejected the auth request.
CHANNEL
56
BAND
5
GHz
SNR
50
dB
RADIUS SERVER
188.3.8.201
802.11 REASON (CODE 23)
802.1X RADIUS failed
Roamed from access point Office-7 then unexpectedly deauthenticated because the auth server rejected the auth request, but the client had a successful connection to SSID WiFI - internal for 4 minutes on access point Office-1.
CHANNEL
64
BAND
5
GHz
SNR
32
dB
TIME TO CONNECT
470
ms
RADIUS SERVER
188.3.8.201
Disconnected from SSID HKWiFi - internal from access point Office-2.
CHANNEL
144
BAND
5
GHz
SNR
34
dB
802.11 REASON (CODE 2)
Invalid authentication
Keith
- Labels:
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Check the Radius server logs and check if the secret is correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
i checked in meraki radius authenticated test, its show all AP passed for authentication test, as our customer is using NPS, i think i need to check in NPS log
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Filter the security event log on the NPS server for events with the IDs 6272 and 6273. 6272=success, and 6273 =failure.
Look at what it says it denied access.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
may i ask below is related with NPS server also ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
checked that the problem machine wireless lan is using 802.11ax, so the 802.11w should be supported on the machine, just wonder why i still receving the auth failure ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Getting the exact same issue in our environment on 5GHZ. It's intermittent and connectivity gets lost for about 10 seconds. Updated drivers on Dell laptop with no success. Using ISE for authentication and no clues spotted in the logs that help.
