I am getting an alert for api.meraki.com certificate expiring on one of our monitoring systems,
api.meraki.com SSL Certificates-HTTP - SSL DaysRemaining
HTTP - SSL Certificate on api.meraki.com is expiring in 6.4719 days, placing the certificate into critical state.
But I cannot find this certificate in our Meraki portal.
How do I replace this? Does it renew itself?
TIA
Solved! Go to solution.
I think it will be renovated by Meraki. 😊
mmhh.. Meraki Website, so they´ll update it.
Of course, it is a Meraki cert! Sorry for the obvious question 🙂
What it looks like to me is a pool of the servers that have had the certificate updated, but a small number have not. I can see it flick between the old and new certificates if I keep repeating the requests.
I opened a support ticket about it to make sure it gets replaced.
I´m getting a similar alert of certificate expiring, but in my case it´s an IMAP certificate.
nXXX.meraki.com SSL Certificates-IMAP - SSL DaysRemaining
IMAP - SSL Certificate on nXXX.meraki.com is expiring in 6.9634 days, placing the certificate into error state.
