Wireless Firewall & traffic shaping question
db3
I looked through the documentation but couldn't see if adding multiple destinations under the wireless > Firewall & traffic shaping is possible. The entry box will let me enter them on individual lines but I'm not sure if this is the proper way to do it besides adding multiple rules for each IP address/subnet I want to block specific access to.
It is not possible to add multiple destinations to the same rule.
5 Replies 5
Like this?  Keep clicking "Add".
db3
Not quite, the specific setting I'm looking at is under a wireless firewall and traffic shaping for rules when connected to a SSID
Doh.  For some reason, I thought you meant traffic shaping rules.
IvanJukic
Meraki Employee All-Star
Hi @db3 ,
If your goal is to block IP/Subnets, there are a few ways this can be achieved. This does depend on your design though. E.g. Enabling a Group Policy to block traffic is a great way.
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/MR_Firewall_Rules
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
