Hi everybody,
I want to create an SSID Guest which permit my guests to create an account on the Meraki Splash Page. It's ok but now I need to set an expiration period time.
For example, when a guest creates an account, he have access on Internet for two hours. After that, he's disconnected. It's possible with Meraki to configure this policy ?
Thank you for your help.
Regards.
Solved! Go to solution.
You can set the "Splash Frequency" on the splash page configuration. This will force the user to re-login through the splash page again after a given duration.
Will that work for you?
Hi
In addition to Splash Page frequency.
Hope you have verified Authorization Parameters available under Network-wide->Users (User management portal).
Is there a way to do this automatically for all users?
From what I can see, you have to highlight a user before you can make any changes to their expiry date.
I can see accounts that were setup in September 2020 and still active.
Thanks for any information.
I'd recommend using a Radius Authentication service like Purple WiFi as it can handle Bandwidth/Time limits which can be unlocked with pre-made voucher codes.
For example, with Purple you can allow 1 hour of Free use every day and have the ability to charge customers for WiFi access or provide a coupon to continue.
You can also limit the amount of data they use rather than set a time limit, eg: 1 GB per day.
Purple makes making a splash page easier and can even integrate with Social media.
Purple Wifi is free up to 5 APs.
If you're in Australia we can help you out with licensing.
