WiFi got disconnected itself with using iPad PRO
Keith_Li
Dear All,
           Rencently deploy merkai AP for our customer, and this sites has been using meraki AP MR44 & 76 for half year, and customer suddently reported their iPad Pro disconnect from ssid often, even standing in one location without walking around and the wifi got disconnected itself, and below is the finding from the devices i use during the test, and i just enabled the 802.11r adaptive and to monitor if its better, and this SSID is using "PSK (WPA2)", do you have any idea what caused such issue ? any help would be appreicated
2 Replies 2
It is saying the client is making bad roaming decisions.  Does the issue only happen in one part of the facility?
Keith_Li
i can say its occur in some part of the area rather than the entire site, i can say its has no issue for window laptop, its happens on android and IOS device, any idea how to resolve it ? also i have a Panasonic tv suddenly not able to join the wifi but its use to be working, below is the package capture, any help would be appreicated
--- Start Of Stream ---
11:03:45.130381 14401291439us tsft 1.0 Mb/s 2462 MHz 11b -59dBm signal -93dBm noise antenna 0 Probe Request () [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit]
11:03:45.131146 14401292238us tsft 1.0 Mb/s 2462 MHz 11b -60dBm signal -93dBm noise antenna 0 Probe Request () [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit]
11:03:47.789254 14403949925us tsft 11.0 Mb/s 2462 MHz 11b -63dBm signal -93dBm noise antenna 0 Authentication (Open System)-1: Successful
11:03:48.333800 14404494775us tsft 11.0 Mb/s 2462 MHz 11b -61dBm signal -93dBm noise antenna 0 Authentication (Open System)-1: Successful
11:03:48.339759 14404500782us tsft 11.0 Mb/s 2462 MHz 11b -62dBm signal -93dBm noise antenna 0 Assoc Request (Inchcape HK - SSO) [11.0 12.0 18.0 24.0 36.0 48.0 54.0 Mbit]
11:03:48.358548 14404496571us tsft 11.0 Mb/s 2462 MHz 11b -67dBm signal -93dBm noise antenna 0 Authentication (Open System)-2:
11:03:48.358571 14404502948us tsft 11.0 Mb/s 2462 MHz 11b -67dBm signal -93dBm noise antenna 0 Assoc Response AID(1) : PRIVACY : Successful
11:03:48.360683 14404506874us tsft 11.0 Mb/s 2462 MHz 11b -93dBm signal -93dBm noise antenna 0 EAPOL key (3) v2, len 95
11:03:48.360697 14404508159us tsft 11.0 Mb/s 2462 MHz 11b -68dBm signal -93dBm noise antenna 0 EAPOL key (3) v2, len 95
11:03:48.361229 14404522208us tsft 11.0 Mb/s 2462 MHz 11b -63dBm signal -93dBm noise antenna 0 EAPOL key (3) v1, len 117
11:03:48.364119 14404525102us tsft 11.0 Mb/s 2462 MHz 11b -63dBm signal -93dBm noise antenna 0 EAPOL key (3) v1, len 95
11:03:48.380608 14404523698us tsft 11.0 Mb/s 2462 MHz 11b -68dBm signal -93dBm noise antenna 0 EAPOL key (3) v2, len 151
11:03:48.448134 14404609018us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP6 :: > ff02::1:ffd1:ee2d: ICMP6, neighbor solicitation, who has fe80::7c97:419:37d1:ee2d, length 32
11:03:48.456710 14404617599us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP6 :: > ff02::16: HBH ICMP6, multicast listener report v2, 1 group record(s), length 28
11:03:48.512624 14404673509us tsft 11.0 Mb/s 2462 MHz 11b -62dBm signal -93dBm noise antenna 0 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 2c:9f:fb:cc:02:c2, length 294
11:03:48.520276 14404681316us tsft 11.0 Mb/s 2462 MHz 11b -63dBm signal -93dBm noise antenna 0 Action (2c:9f:fb:cc:02:c2): BA ADDBA Response
11:03:48.540687 14404682896us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 192.168.1.1.67 > 192.168.1.167.68: BOOTP/DHCP, Reply, length 309
11:03:48.576767 14404737653us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP6 :: > ff02::16: HBH ICMP6, multicast listener report v2, 2 group record(s), length 48
11:03:48.576984 14404737800us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP 192.168.1.167 > 224.0.0.22: igmp v3 report, 1 group record(s)
11:03:48.679861 14404840755us tsft 11.0 Mb/s 2462 MHz 11b -64dBm signal -93dBm noise antenna 0 ARP, Request who-has 192.168.1.1 tell 192.168.1.167, length 28
11:03:48.683343 14404844381us tsft 11.0 Mb/s 2462 MHz 11b -63dBm signal -93dBm noise antenna 0 Action (2c:9f:fb:cc:02:c2): BA ADDBA Response
11:03:48.687399 14404848349us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP 192.168.1.167.37944 > 1.1.1.1.853: Flags [S], seq 4208313853, win 65535, options [mss 1460,sackOK,TS val 609835576 ecr 0,nop,wscale 6], length 0
11:03:48.687471 14404848460us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP 192.168.1.167.58580 > 8.8.8.8.853: Flags [S], seq 1673254714, win 65535, options [mss 1460,sackOK,TS val 2991606094 ecr 0,nop,wscale 6], length 0
11:03:48.694002 14404855032us tsft 11.0 Mb/s 2462 MHz 11b -64dBm signal -93dBm noise antenna 0 Action (2c:9f:fb:cc:02:c2): BA ADDBA Response
11:03:48.694589 14404855606us tsft bad-fcs 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 117.0 Mb/s MCS 14 20 MHz long GI IP 192.168.1.167.58580 > 8.8.8.8.853: Flags [.], ack 76966128, win 1024, options [nop,nop,TS val 2991606109 ecr 3560799699], length 0
11:03:48.694718 14404855752us tsft bad-fcs 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 117.0 Mb/s MCS 14 20 MHz long GI IP 192.168.1.167.42196 > 136.0.8.8.1812: Flags [.], ack 146008820, win 1024, options [[bad opt]
11:03:48.694811 14404845997us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI ARP, Reply 192.168.1.1 is-at 04:d5:90:81:d8:e3, length 46
11:03:48.695262 14404856253us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 104.0 Mb/s MCS 13 20 MHz long GI IP 192.168.1.167.58580 > 8.8.8.8.853: Flags [.], ack 2147483649, win 1024, options [nop,nop,TS val 2991606109 ecr 3560799699], length 0
11:03:48.697672 14404858652us tsft 2462 MHz 11n -63dBm signal -93dBm noise antenna 0 117.0 Mb/s MCS 14 20 MHz long GI IP 192.168.1.167.58580 > 8.8.8.8.853: Flags [P.], seq 0:135, ack 2147483649, win 1024, options [nop,nop,TS val 2991606109 ecr 3560799699], length 135
11:03:48.700284 14404861261us tsft 2462 MHz 11n -61dBm signal -93dBm noise antenna 0 117.0 Mb/s MCS 14 20 MHz long GI IP 192.168.1.167.37944 > 1.1.1.1.853: Flags [.], ack 1014536596, win 1024, options [nop,nop,TS val 609835594 ecr 1363163293], length 0
11:03:48.700363 14404861379us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP 192.168.1.167.37944 > 1.1.1.1.853: Flags [P.], seq 0:135, ack 1, win 1024, options [nop,nop,TS val 609835594 ecr 1363163293], length 135
11:03:48.707236 14404868197us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 117.0 Mb/s MCS 14 20 MHz long GI IP 192.168.1.167.37944 > 1.1.1.1.853: Flags [.], ack 1449, win 1070, options [nop,nop,TS val 609835603 ecr 1363163306], length 0
11:03:48.708483 14404869472us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 117.0 Mb/s MCS 14 20 MHz long GI IP 192.168.1.167.37944 > 1.1.1.1.853: Flags [.], ack 2897, win 1115, options [nop,nop,TS val 609835603 ecr 1363163306], length 0
11:03:48.709014 14404870028us tsft 2462 MHz 11n -61dBm signal -93dBm noise antenna 0 117.0 Mb/s MCS 14 20 MHz long GI IP 192.168.1.167.37944 > 1.1.1.1.853: Flags [.], ack 3146, win 1160, options [nop,nop,TS val 609835603 ecr 1363163306], length 0
11:03:48.710740 14404861938us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [S.], seq 1014536595, ack 4208313854, win 65535, options [mss 1460,sackOK,TS val 1363163293 ecr 609835576,nop,wscale 13], length 0
11:03:48.710761 14404864411us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [S.], seq 1014536595, ack 4208313854, win 65535, options [mss 1460,sackOK,TS val 1363163293 ecr 609835576,nop,wscale 13], length 0
11:03:48.710774 14404865860us tsft 2462 MHz 11n -68dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [S.], seq 1014536595, ack 4208313854, win 65535, options [mss 1460,sackOK,TS val 1363163293 ecr 609835576,nop,wscale 13], length 0
11:03:48.710778 14404865860us tsft 2462 MHz 11n -68dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [.], ack 136, win 9, options [nop,nop,TS val 1363163306 ecr 609835594], length 0
11:03:48.710783 14404865860us tsft 2462 MHz 11n -68dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [.], seq 1:1449, ack 136, win 9, options [nop,nop,TS val 1363163306 ecr 609835594], length 1448
11:03:48.710790 14404865860us tsft 2462 MHz 11n -68dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [.], seq 1449:2897, ack 136, win 9, options [nop,nop,TS val 1363163306 ecr 609835594], length 1448
11:03:48.710797 14404865860us tsft 2462 MHz 11n -68dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 2897:3146, ack 136, win 9, options [nop,nop,TS val 1363163306 ecr 609835594], length 249
11:03:48.720873 14404881818us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP 192.168.1.167.58580 > 8.8.8.8.853: Flags [.], ack 2147485049, win 1068, options [nop,nop,TS val 2991606133 ecr 3560799722], length 0
11:03:48.720946 14404881928us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP 192.168.1.167.58580 > 8.8.8.8.853: Flags [.], ack 2147486449, win 1112, options [nop,nop,TS val 2991606135 ecr 3560799722], length 0
11:03:48.721166 14404882192us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP 192.168.1.167.58580 > 8.8.8.8.853: Flags [.], ack 2147487849, win 1156, options [nop,nop,TS val 2991606135 ecr 3560799722], length 0
11:03:48.721279 14404882303us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP 192.168.1.167.58580 > 8.8.8.8.853: Flags [.], ack 2147488190, win 1199, options [nop,nop,TS val 2991606136 ecr 3560799722], length 0
11:03:48.722221 14404883224us tsft 2462 MHz 11n -62dBm signal -93dBm noise antenna 0 130.0 Mb/s MCS 15 20 MHz long GI IP 192.168.1.167.37944 > 1.1.1.1.853: Flags [P.], seq 136:229, ack 3146, win 1160, options [nop,nop,TS val 609835619 ecr 1363163306], length 93
11:03:48.724147 14404885191us tsft 11.0 Mb/s 2462 MHz 11b -63dBm signal -93dBm noise antenna 0 Action (2c:9f:fb:cc:02:c2): BA ADDBA Request
11:03:48.729335 14404868749us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [S.], seq 2224449775, ack 1673254715, win 65535, options [mss 1412,sackOK,TS val 3560799699 ecr 2991606094,nop,wscale 8], length 0
11:03:48.729337 14404868749us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], ack 136, win 261, options [nop,nop,TS val 3560799709 ecr 2991606109], length 0
11:03:48.729339 14404868749us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58566: Flags [F.], seq 1050531997, ack 4017727958, win 261, options [nop,nop,TS val 2812816537 ecr 2991567562], length 0
11:03:48.729366 14404870216us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [S.], seq 2224449775, ack 1673254715, win 65535, options [mss 1412,sackOK,TS val 3560799699 ecr 2991606094,nop,wscale 8], length 0
11:03:48.729368 14404870216us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], ack 136, win 261, options [nop,nop,TS val 3560799709 ecr 2991606109], length 0
11:03:48.729369 14404870216us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58566: Flags [F.], seq 0, ack 1, win 261, options [nop,nop,TS val 2812816537 ecr 2991567562], length 0
11:03:48.729396 14404871061us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [S.], seq 2224449775, ack 1673254715, win 65535, options [mss 1412,sackOK,TS val 3560799699 ecr 2991606094,nop,wscale 8], length 0
11:03:48.729398 14404871061us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], ack 136, win 261, options [nop,nop,TS val 3560799709 ecr 2991606109], length 0
11:03:48.729399 14404871061us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58566: Flags [F.], seq 0, ack 1, win 261, options [nop,nop,TS val 2812816537 ecr 2991567562], length 0
11:03:48.729580 14404874255us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [S.], seq 2224449775, ack 1673254715, win 65535, options [mss 1412,sackOK,TS val 3560799699 ecr 2991606094,nop,wscale 8], length 0
11:03:48.729582 14404874255us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], ack 136, win 261, options [nop,nop,TS val 3560799709 ecr 2991606109], length 0
11:03:48.729583 14404874255us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58566: Flags [F.], seq 0, ack 1, win 261, options [nop,nop,TS val 2812816537 ecr 2991567562], length 0
11:03:48.729609 14404875040us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [S.], seq 2224449775, ack 1673254715, win 65535, options [mss 1412,sackOK,TS val 3560799699 ecr 2991606094,nop,wscale 8], length 0
11:03:48.729611 14404875040us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], ack 136, win 261, options [nop,nop,TS val 3560799709 ecr 2991606109], length 0
11:03:48.729613 14404875040us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58566: Flags [F.], seq 0, ack 1, win 261, options [nop,nop,TS val 2812816537 ecr 2991567562], length 0
11:03:48.729638 14404876694us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [S.], seq 2224449775, ack 1673254715, win 65535, options [mss 1412,sackOK,TS val 3560799699 ecr 2991606094,nop,wscale 8], length 0
11:03:48.729640 14404876694us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], ack 136, win 261, options [nop,nop,TS val 3560799709 ecr 2991606109], length 0
11:03:48.729641 14404876694us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58566: Flags [F.], seq 0, ack 1, win 261, options [nop,nop,TS val 2812816537 ecr 2991567562], length 0
11:03:48.729686 14404877875us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [S.], seq 2224449775, ack 1673254715, win 65535, options [mss 1412,sackOK,TS val 3560799699 ecr 2991606094,nop,wscale 8], length 0
11:03:48.729688 14404877875us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], ack 136, win 261, options [nop,nop,TS val 3560799709 ecr 2991606109], length 0
11:03:48.729690 14404877875us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58566: Flags [F.], seq 0, ack 1, win 261, options [nop,nop,TS val 2812816537 ecr 2991567562], length 0
11:03:48.729691 14404877875us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], seq 1:1401, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 1400
11:03:48.729693 14404877875us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], seq 1401:2801, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 1400
11:03:48.729694 14404877875us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [P.], seq 2801:4201, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 1400
11:03:48.729696 14404877875us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [P.], seq 4201:4542, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 341
11:03:48.729734 14404879559us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [S.], seq 2224449775, ack 1673254715, win 65535, options [mss 1412,sackOK,TS val 3560799699 ecr 2991606094,nop,wscale 8], length 0
11:03:48.729736 14404879559us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], ack 136, win 261, options [nop,nop,TS val 3560799709 ecr 2991606109], length 0
11:03:48.729737 14404879559us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58566: Flags [F.], seq 0, ack 1, win 261, options [nop,nop,TS val 2812816537 ecr 2991567562], length 0
11:03:48.729738 14404879559us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], seq 1:1401, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 1400
11:03:48.729740 14404879559us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], seq 1401:2801, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 1400
11:03:48.729742 14404879559us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [P.], seq 2801:4201, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 1400
11:03:48.729743 14404879559us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [P.], seq 4201:4542, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 341
11:03:48.729757 14404883304us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [S.], seq 2224449775, ack 1673254715, win 65535, options [mss 1412,sackOK,TS val 3560799699 ecr 2991606094,nop,wscale 8], length 0
11:03:48.729762 14404883304us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], ack 136, win 261, options [nop,nop,TS val 3560799709 ecr 2991606109], length 0
11:03:48.729766 14404883304us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58566: Flags [F.], seq 0, ack 1, win 261, options [nop,nop,TS val 2812816537 ecr 2991567562], length 0
11:03:48.729770 14404883304us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], seq 1:1401, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 1400
11:03:48.729776 14404883304us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [.], seq 1401:2801, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 1400
11:03:48.729782 14404883304us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [P.], seq 2801:4201, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 1400
11:03:48.729788 14404883304us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 8.8.8.8.853 > 192.168.1.167.58580: Flags [P.], seq 4201:4542, ack 136, win 261, options [nop,nop,TS val 3560799722 ecr 2991606109], length 341
11:03:48.758567 14404886043us tsft 11.0 Mb/s 2462 MHz 11b -67dBm signal -93dBm noise antenna 0 Action (02:7b:c8:ab:6f:cd): BA ADDBA Response
11:03:48.762736 14404888889us tsft 2462 MHz 11n -66dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163328 ecr 609835619], length 258
11:03:48.972637 14405101932us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163543 ecr 609835619], length 258
11:03:48.972657 14405102729us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163543 ecr 609835619], length 258
11:03:48.972676 14405103517us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163543 ecr 609835619], length 258
11:03:48.972692 14405104281us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 7.2 Mb/s MCS 0 20 MHz short GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163543 ecr 609835619], length 258
11:03:48.972709 14405105069us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 6.5 Mb/s MCS 0 20 MHz long GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163543 ecr 609835619], length 258
11:03:48.972740 14405106325us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 6.5 Mb/s MCS 0 20 MHz long GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163543 ecr 609835619], length 258
11:03:48.972756 14405107084us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 6.5 Mb/s MCS 0 20 MHz long GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163543 ecr 609835619], length 258
11:03:48.972777 14405107843us tsft 2462 MHz 11n -93dBm signal -93dBm noise antenna 0 6.5 Mb/s MCS 0 20 MHz long GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163543 ecr 609835619], length 258
11:03:48.972790 14405109155us tsft 2462 MHz 11n -67dBm signal -93dBm noise antenna 0 6.5 Mb/s MCS 0 20 MHz long GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163543 ecr 609835619], length 258
11:03:49.172659 14405316878us tsft 2462 MHz 11n -66dBm signal -93dBm noise antenna 0 6.5 Mb/s MCS 0 20 MHz long GI IP 1.1.1.1.853 > 192.168.1.167.37944: Flags [P.], seq 3146:3404, ack 229, win 9, options [nop,nop,TS val 1363163758 ecr 609835619], length 258
11:03:53.694638 14409855503us tsft 11.0 Mb/s 2462 MHz 11b -63dBm signal -93dBm noise antenna 0 ARP, Reply 192.168.1.167 is-at 2c:9f:fb:cc:02:c2, length 28
keith
